Speed tests
Speed tests
Can people on the 1meg package post their speed test results from both the Plusnet speed test and from dslreports.com ?
My results are....
Plusnet - 970.30kbps
dslreports - 782kbps
This difference always remains and would just like to see if it is a problem with my connection only.
Thanks in advance.
Paul
Speed tests
The dslreport.com speed tests are rubbish. They are based in the US, and as such, subject to all the routing latency that US transit has to offer.
See the Speed tester reliability FAQ for details my speed testers are usless in genral anyhow.
Speed tests
The best way to test your speed is to time the download of a large file and see what average speed you can achieve. Or use the download pop-up's that can show your average transfer speed.
The speed testers can only be used as a guide and the further away they are the slower they will normally report your actual speed to them.
zpeterk
Speed tests
I used to get 117kbs on my one mb connection on a download
Speed tests
i normally get 121kbs Smiley
Speed tests
If you want a UK based test thats more reliable i'd use ADSLGuide's Speedtest
Hope that helps Smiley
