Speed test
Speed test
PlusNET Technologies Bandwidth Meter
Your current bandwidth reading is:
165.70kbps
This is not good it gets to 6pm and the speed drops to this whats wrong Huh?
RE: Speed test
You have checked that your MTU is 1458 and your RWIN value is set correctly, thats what i had to do to DRASTICALLY increase my speeds.
Dave Allan
RE: Speed test
> Dave Allan
No i have no can you point me in the right direction thanks
RE: Speed test
Ok ill try,
Start by visiting here.
It should tell you everything you need to know and do and keep you from manually editing the registry which is the way i did it.
I found it as easy to do it that way though.
If you need anymore help post.
Dave Allan
Brickinit
RE: Speed test
> Ok ill try,
> Dave Allan7
dave
i think maybe you should give him a site to visit,as i don't think a blank space will help him much!
malc
:confused:
RE: Speed test
> Ok ill try,
> Dave Allan
you say here where ?
RE: Speed test
