Speed problems
Speed problems
I have the same intermittent browsing problems. Sometimes it's quick then seconds later it's slow and often chokes, it's extremely irratating.
Can anyone help? Anyone else had the same probs and fixed them and if so how?
DNS servers are:
212.159.6.9 and 212.159.6.10
Report is below, it shows some serious lag in the worst times.
Traceroute Results: http://cgi.support.plus.com/faultreporting/tracert.php?tracertid=8742869
Traceroute Time (24 Hour): 10:24 to 10:27
Traceroute Duration: 3 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: BANBURY
Problem: Latency / Choke
Other Problem Experienced: The speed test results are inaccurate because the plus net speed test said the speed was 0 repeatedly.
The problem is intermittant (I don\'t think I spelt that right), sometimes browser is fast as you would expect but other times it chokes or is way below dialup type speeds.
As the plus net speed test reported 0 I have tested on zdnet test and that reported expected speeds and yet the problem remains.
Duration of Problem: Since installation
Minimum Speed Achieved On PlusNet Speedtest: 50 kbps
Maximum Speed Achieved On PlusNet Speedtest: 50 kbps
Average Speed Achieved On PlusNet Speedtest: 50 kbps
Account: ADSL Home (Self Install) - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: Please discuss this issue with Paul Howlett, he installed the equipment and is a plus net customer and put the data for these tests together.
