Speed problem
Speed problem
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 23:05 to 23:25
Traceroute Duration: 20 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Chiswick
Problem: Other (Please explain below)
Other Problem Experienced: experiencing extremely slow browsing/downloading, found out that if I use my phone while browsing I get full speed
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 49 kbps
Maximum Speed Achieved On PlusNet Speedtest: 927 kbps
Average Speed Achieved On PlusNet Speedtest: 488 kbps
Account: ADSL Home (Self Install) - 1mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
1 REPLY
Speed problem
The packet loss may be a contributing factor in your issue and it looks like it may be within BTs network (because the loss is consistant on all the hops you see so is likely to be a loss before the first hop) or your router is losing packets. Have you tried a power cycle on the router and if that does not help, disconnect from the wallsocket for 30 minutes then try again..
You need to raise a contact us ticket for this if the abobe does not help so PlusNet can investigate further and most likely pass the issue to BT.
