Speed Upgrade and moving house.
I am currently in the process of getting my ADSL account moved to a new number due to a house move, will this affect my automatic upgrade? Does this mean I will get upgraded quicker than if I was to merely wait until the rollout had been completed?
According to the BT engineer that installed my new phone line, I should be alright to receive the full 2mb speed as I live very close to the exchange.
I think you will probably find that when you move you will be on 2 meg without waiting. Cool
Its a new provide at your new premises and they seem to be doing new provisions now at the full speed the line will support. Smiley
that was certainly the case for me Cheesy
i think plusnet''s policy is to provision you at the fastest speed possible at the BT end and then dependant upon your product control your speed. So although my router synced at 2272, I had to prompt plusnet to remove the throttle on my connection to get the use of it (to be fair i was still on the home 1mb lite package at the time).
