Speed Tests (hopefully there will be some action)
Downstream 396 Kbps (49.5 KB/sec) 455 Kbps (inc. overheads)
Upstream 217 Kbps (27.1 KB/sec) 249 Kbps (inc. overheads)
RE: Speed Tests (hopefully there will be some action)
Hey Christian look ayt your upstream
look at mine
Downstream 465 Kbps (58.1 KB/sec) 534 Kbps (inc. overheads)
Upstream 43 Kbps (5.4 KB/sec) 49 Kbps (inc. overheads)
:angryfire:
chino
There not bad!! i do get a bit more but atleast plus.net are working on this.
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
thanks for the posts i am haveing a bit more joy even though my upload speeds were only 5k sometimes
fingers crossed this should get better sorry for all the bad ***** i said i was well pithed off
anyways thanks Smiley
What utility do you guys use to test the speeds?Huh
Phantom_Flan_Fl
By the looks of it, it's the speed test from ADSLguide.org
chino
Most of then use www.adslguide.org the best way i say is d/l a file if you have a problem then contact plus.net
For an example i have just d/l this file:
URL http://205.188.160.44/hansdelans/bj04.ork
File Size 7282637
Completed 7282637
Total Time 00:02:19
Average Speed 51.17 KB/s
Create Time 11/03/02 09:14:47
Complete Time 11/03/02 09:28:47
on simular files i can get:
Average Speed 55.89 KB/s
see if anyone gets these sort of speeds?
cUnDaLl
p.s. i use a d/l agent (flash get)
Thanks for the info!
Kind regards
hey mR cUnDaLl
wots your connection like
how long does it take you to log-on
wot asdl modem have you got
were abouts do you live (not for stalking reasons)Smiley
wot is your upload speed
would you be prepared to pay extra money for a faster conection 512/512 or 1024/256 etc
how much would you be prepared to pay for the faster conection
and would this faster package (if available with plusnet) be better etc i think you might understand this all as you seem pretty clued up on it all
PS sorry for the bad posts in the forums i only hope you can forgive my bad temper i just am pithed off
pss i am asking you as there is not much feedback from plusnet and you seem clued up etc
chrisSmiley
psssssss please reply to this mR cUnDaLl
do more then one test
test1
Direction Actual Speed True Speed
Downstream 165 Kbps (20.6 KB/sec) 189 Kbps (inc. overheads)
Upstream 241 Kbps (30.1 KB/sec) 277 Kbps (inc. overheads)
test2
Downstream 459 Kbps (57.4 KB/sec) 527 Kbps (inc. overheads)
Upstream 232 Kbps (29.0 KB/sec) 266 Kbps (inc. overheads)
test3
Upstream 234 Kbps (29.3 KB/sec) 269 Kbps (inc. overheads)
test4
chino
I am on a standard ADSL Home account 512kbps running from Coventry (02476).
I have the Conexant PCI modem with the latest drivers and it all seems fine, i don't do speed tests as you usally get people doing over and over again which leads them to be overloaded, so all i do is carry on d/l from big firms to check me speed link the link above it's aol and i always get 50kbps from them..
cUnDaLl
p.s. i always use a d/l agent (flashget)
seem simalar setup i got conextant modem
got from jungle.com
thanks again for your help you shold be an employee
you deserve a gold medal for putting up with me
Smiley Smiley thanks again
chrisSmiley
chino
well i might be going to work for them after my last year at uni (this summer)
What drivers do you have?
cUnDaLl
original cd drivers that came with it
this is something i have never though about
modem drivers lol
i update my video card drivers/soundcard drivers/etc but never even though of updateing the modem ones??
thanks new ideas ,,,, this is good
i will look for them now :@)
chino
You can check your version via the control pannel:
The latest drivers i have found are at:
http://www.cundall.plus.com/Conexant/
cUnDaLl
