Speed Tests ( Using Plusnet speed tester )
Your current bandwidth reading is:
460.80kbps
which means you can download at 57.6 KB/sec. from our servers.
RE: Speed Tests ( Using Plusnet speed tester )
Plusnet have there own speed tester?
o yes you just have to look hard and then you will find it
Wink
This mornings tests 26th september 08:48
PlusNET Technologies Bandwidth Meter
499.30kbps
which means you can download at 62.41 KB/sec. from our servers.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
499.3 kbps YOU
500 kbps ADSL 500
1000 kbps ADSL 1000
2000 kbps ADSL 2000
Retest Close
Maybe you're just scraping past 61 K peak when downloading from PlusNet, as it's your ISP.
But you won't get 61 K constant on the internet from other servers. no way!.
Downloads on here start slow then speed up.. but not to over 59 or 60K then they slow down and then up again.
Use your own testing equipment and you shall see the true readings!
Jason
REAL Download speed at moment from a US server:
SESSION START: 26/09/2002 15:43:17
Start Test: 26/09/2002 15:43:29
Test Type: Download 1 megabyte
Operating System: Windows XP
-------------Settings Used------------
[D-Link DSL-200 USB ADSL Modem(WAN)] Maximum Transfer Unit: 1500
[Realtek RTL8139/810X Family Fast Ethernet NIC] Maximum Transfer Unit: 1500
[1394 Net Adapter] Maximum Transfer Unit: 1500
Tcp Receive Window: 256960
Time To Live: 64
Black Hole Detection: False
Auto-Detect Maximum Transfer Unit: True
Maximum number of simultaneous HTTP 1.0 Connections: 10
Maximum number of simultaneous HTTP 1.1 Connections: 8
Tcp Options: 1 - Window Scaling but no Timestamp Options
Fast Retransmission and Recovery support value: 3
Support for Selective Acknowledgements: True
Data Transfer Start: 26/09/2002 15:43:31
Data Transfer Complete: 26/09/2002 15:43:49
--->Total Data Received: 1025.34 kilobytes
--->Time to Complete Transfer: 00:00:18:000
--->Average Speed: 56.84 kilobytes per second
--->Peak Speed: 61.24 kilobytes per second
You see it only peeks at 61 K
it isn't constant. i wish it was!
Jason
Im afraid that i must say taht my download speeds are in excess of 57-63 and i downloading all the time really.
And i running a basic home budget network through 3 machines.
The plusnet ADSL is sorted as far as im concerned.
karlhedges@hotmail.com
i get 62k from dc++
i get over 62 k from tucows
i get more then 62 k even from microsoft.com
also wuinamp.com
etc
it must be just your conection thats poor
hi all
where can I do a speed test on plusnet
from Carl
