Speed Problems
Speed Problems
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 22:10 to 22:17
Traceroute Duration: 7 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Sauchen
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 924 kbps
Maximum Speed Achieved On PlusNet Speedtest: 862 kbps
Average Speed Achieved On PlusNet Speedtest: 893 kbps
Account: ADSL Home (Self Install) - 2mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: Recently Upgrade from 512kB to 2MB, but have only achieved speed tests of around 860-920kB (the equivalent of a 1MB package).
Speed Problems
Are you sure your connected at 2Mb. Have you checked your modem/router to see what speed it is syncing at?
Can you also run the BT Speedtest and see if you get similar speeds. See ADSL: Using BT’s Speed tester service. If that reports similar speeds and you are connected at 2Mb then that indicates a BT issue.
Speed Problems
The NetGear DG834G Router shows the following modem status:
Modem
ADSL Firmware Version 1.00.09.00
Modem Status Connected
DownStream Connection Speed 2272 kbps
UpStream Connection Speed 288 kbps
VPI 0
VCI 38
I have run the PlusNet speed test this evening and get the following results:
Date, Speed Achieved (kbps)
14-12-2004 20:56:15, 1896.7
14-12-2004 20:55:50, 1890.1
This appears to be up to speed now. I will monitor the spped status.
Many thanks
Alun
flicker
Speed Problems
Lucky you.
Your current speed is:
516.30kbps
Great if you are on 512, but mine is supposed to be 1MB. Its the same every night. Not good enough.
flicker
Speed Problems
Things just better and better - I disconnected for about 10 mins, now I've got
468.30kbps
Evil
flicker
Speed Problems
Well, why aren't I surprised, look at my latest reading for 13.27
949.80kbps
Isn't it strange that my speeds are always extremely pleasing during the daytime but as soon as it gets past about 5pm, it's uselessly pathetic? :?
