Speed Problem
Speed Problem
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 06:10 to 06:47
Traceroute Duration: 37 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Padgate
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 481.5 kbps
Maximum Speed Achieved On PlusNet Speedtest: 496.5 kbps
Average Speed Achieved On PlusNet Speedtest: 489 kbps
Account: Please Select... (1Mb Self Install ADSL)
IP Block Size: Single (default)
Ticket Number: 13921890
Additional Information: This has only happened since the BT engineer has repaired the previous fault
1 REPLY
Speed Problem
Have you tried powering down your modem or router you are probably on a congested pipe, there is an issue with load balancing that plusnet have acknowleged.
