Speed Explanation
Speed Explanation
Hi peeps wonder if anyone can explain the following..
MAXED 16/6
Previously on a 1mb connection - Dl speeds in the high 800s to low 900s
Maxed 16/6 synched at 2.6mb SNR 6.5 - PN speed test 1.9mb hurrah I thought.
All worked fine, went to work came back at 7pm and constant disconnections, in fact would not stay connected. Left it overnight and checked 1st thing next day. Interleaving now on and synching at 1.5 to 2.2mb but dl speeds only .98mb.
Should dl speeds be 1/2 or less of synch speed
Current stats Synch 2.272mb SNR 7.5 - dl .98mb
any thoughts would be welcome
Speed Explanation
PS - Still using original PN splitter/filter should I spend some dosh and get a better one?
Speed Explanation
a high quality filter and shielded cable will help you a bit
cable like this
http://www.broadbandstuff.co.uk/product_info.php?products_id=310&osCsid=e833e6c020d4bb7e99a3cd794eaf...
and microfilter like this
http://www.broadbandstuff.co.uk/product_info.php?cPath=28&products_id=123&osCsid=e833e6c020d4bb7e99a...
should improve your stats, it dropped my attenuation by 10dB and raised SNR by 10-15dB back when i was on 2mbit, altho now i, like yourself am struggling
Speed Explanation
Synch speed is fine.. what I don't understand is why download speed is so much lower than synch speed.
Cheers for the info fella
hitachi
Speed Explanation
During the period of disconnections BT may well have taken your lowest connection and set that as the maximum throuput it would allow,
It will now take 3 days or so of faster connections before BT will raise your throuput to match the present connection speed.
Speed Explanation
cheers grasc have ordered - way cheaper than pcworld too,..
NOW GOT A PN MSR OF 1000 GRRRRRRRRRRRRRR
thought that didnt set for 10 days!
