Some Sites Work Some Don't
Anyone know what the problem could be, I'm sharing the connection over a network but not all sites work, yahoo! and plus.net work but site like download.com and microsoft sites don't work.
I've scanned for virus', adware and stuff like that and my pc is clean. anyone know what the problem could be?
p_w_d_stone
Are you able to run a nslookup and tracert on sites that don't work on your connection.
Like i said Microsoft Sites dont't work so.. Cheesy I can't read those pages. could you give me the jist of them. thanks
Fixes: 45
Check your MTU setting on the router, this can cause problems with some sites if it's set too low. Try it at 1492.
My Network is set up like this.
Internet --USB Modem--> PC Downstairs ----> PC Upstairs ----> Xbox 360
Now my modem doesn't have an ethernet port just a phone jack, so all networking is done through Pc's network cards.
So I'm not sure if i can get to my MTU, any ideas?
Fantasticfourum
Just a thought,have you got Peer Guardian installed because this can prevent you from going to certain sites ?
Nah I don't is that like Net nanny or something (not that i have that)
Also I can't sign in to MSN messenger. (but I can on the 360)
I use normal ICS with Windows.
Fixes: 45
Use DrTcp http://www.dslreports.com/drtcp to check/Set MTU settings. 'fraid i've not got much experience with USB modems and ICS ( routers are much easier to configure ). Have a google for 'ics' and 'mtu' and there are quite a few tips out there. Just make a note of the MTU settings before you change any , so you can always put them back if it doesnt work!!
I Tried that, but It didn't tell me anything every box was just blank
if MTU box is blank that means its set to 1500
try putting a smaller fgiure into the MTU box, save and reboot.
i've run into the problem you describe and i found i needed to set MTU ~1480 to get MS sites working
Thanks so much, your a life saver. changed it and after a quick restart its been working fine. Wonder why it got changed in the first place.
i exist only to serve Cool
