Solwise Sar110 Doesn't Retain Settings
Hi
I've been trying to set up a web server at home, and have managed to add a rule to the router software and get the server working fine. However, when I power down the router and then start it up again the next day, the settings I had made have been lost and the default ones are there again.
I think that when setting up the router the problem of settings not being remembered also occurred, but after a while of re-entering them it seemed to remember them.
Any advice on how to overcome this problem would be appreciated, or maybe I’m just missing a 'save' button or something in the software. Would the most recent firmware version I’ve heard about solve this problem?
RE: Solwise Sar110 Doesn't Retain Settings
Are you pressing the submit button. After entering the rule etc. Then goto Admin Tab> and press "Commit " This will save the settings. Even if you power down the router
Hi
Thanks for your help Smiley
