Solwise SAR110 not accepting password
Trying to log on to it via IE6 but it is not accepting the password?
Is there any way of forcing it back to default settings?
thanks
jberry
You can reset the router to its default settings using the console cable. There is a guide on using hyperterminal in the SAR110 section of the support pages.
Once you are conneted via console just type:
reboot default(s)
(I can't remember whether it is plural or not off the top of my head so try both, without the brackets of course).
Regards,
Have you changed the password? If not it should just be 'admin' or something similar. I had problems when I was changing the password, but was interupted by a powercut.
