Solwise Routers
Solwise Routers
Hi All,
Have a solwise router supplied by Plusnet.
I'm having a small problem where the router seems to drop the tcp session every now and again.
My MSN constantly drops every 30mins or so!
Does anyone know if there are any issues with the solwise routers dropping the connection or tcp sessions abnormally?
Thanks and Regards
Chris
RE: Solwise Routers
You should try to confirm it is the router that is dropping the connection.
While it doesn't happen that often for me, MSN is a known pain, and drops often enough, no matter what hardware used.
RE: Solwise Routers
Hi Phillip,
It's not just MSN, Everything drops, like the entire connection has been dropped and then comes back up.
I've switched back to my smoothie firewall and Frog atm to see if it still happens
Cheers
