Slow on Kazaa
Slow on Kazaa
Is anyone else experiencing really slow downloads from Kazaa lately?? For the past couple of days the best I've managed is about 5.00kb/s, whereas I used to enjoy speeds of up to 50kb/s.
Users downloading from me seem to be working fine and very fast.
I'm on ADSL Home with SAR110 Router.
Your thoughts?
Slow on Kazaa
Your P2P download speed is dependant on who you are downloading from. So if your downloading from some 56ker then you get 5k maybe 8k at best. So read the faq's about speed issues on the p2p sites as they will tell you exactly the same thing.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Slow on Kazaa
I had a similar problem, with really low speeds, even with 8 users to download from. The only way i solved it, was to downgrade to Kazaalite 1.72 retro edition, works ok now. Give it a go.
