Slow logon
Slow logon
On a dual boot Win 2000 and Win ME, Win 2000 at logon connects to the network in probably less than 5 seconds. Win ME takes up to 2 minutes to complete the same connection, which is considerably slower than is was before I upgraded to ADSL...anybody know why?
PL
RE: Slow logon
Do you have "login to network" ticked in the connection settings?
RE: Slow logon
Uhmm...don't know I'll take a look when I get home to my PC, but thanks anyway
Peter
RE: Slow logon
Peter
