Slow internet connection
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.0.1 - 0 | 1246 | 1246 | 0 | 0 | 0 | 0 |
| lo0.plusnet.pth-ag1.plus.net - 3 | 1246 | 1217 | 10 | 23 | 81 | 20 |
| gi1-2.vlan3.pth-gw3.plus.net - 4 | 1246 | 1204 | 10 | 23 | 70 | 20 |
| ge0-1-0-22.ptn-gw1.plus.net - 5 | 1246 | 1196 | 10 | 24 | 91 | 10 |
| linx-gw2.ja.net - 3 | 1246 | 1210 | 10 | 24 | 70 | 10 |
| po2-1.lond-scr3.ja.net - 4 | 1246 | 1202 | 10 | 29 | 230 | 20 |
| po6-0.read-scr.ja.net - 4 | 1246 | 1199 | 10 | 26 | 81 | 20 |
| po2-0.bris-scr.ja.net - 4 | 1246 | 1200 | 10 | 39 | 291 | 20 |
| po1-0.bris-bar3.ja.net - 5 | 1246 | 1195 | 10 | 28 | 71 | 20 |
| No response from host - 100 | 1246 | 0 | 0 | 0 | 0 | 0 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
1 REPLY
Posting a ping trace does not actually explain what problem you are trying to report. Also the above does not show your ADSL speed if that is what you are trying to report as slow.
From the above, your ping times are fine so I'm not sure what it is you are trying to show us - the last entry can have many reasons including the router/server not responding to pings and does not necessarily mean there is a problem. Also as you don;y say what server you were trying to contact it's impossible for me and others to try the same thing.
Could you explain what it is you are having problems with (i.e. what is slow) and we may then be able to help.
