Slow connection
Slow connection
I've finally got my ADSL router after waiting 3 weeks for stock (DG814) and everything worked OK yippee. Well done to Plusnet and Netgear's setup wizard. BUT the connection is slower than I would expect. I tried to download a file and IE6 on an XP machine gave about 6Kb/s average download speed. My 56K modem gave about 4Kb/s. This was at 2230 on a Thursday night. Can anyone help because I'm sure this is not right (I've used broadband elsewhere so much quicker). Thanks.
RE: Slow connection
This can sometimes be due to the speed of the server you're downloading from, can you try downloading a file from the file vault? (in the My Tools menu above). Please let us know what speeds you get.
Regards,
Rob
| Robert Kelly...............Unmetered & ADSL solutions
| Technical Support......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
RE: Slow connection
You can test your speed at http://www.adslguide.org/tools/speedtest.asp
My experience with Plus Net is that it is quite a lot slower than usual for broadband. But for some reason new customers experience good performance.
