Slow connection-help pse!
pixgunnill
I may be " going thru the upgrade speed process". Last week my speeds dropped very badly-slower than dial up. The situation cleared after three days, but the same has happened again this week. Is this part of the upgrade process? Grateful for any comments please
Mike
hillers
might be, check your router/modem settings (downstream and upstream)to see if you've been maxed, that was the first I knew about it, since I found out only by investigating why I was having so many disconnections
pixgunnill
Thank you for your answer, I have now been told that it is a line quality problem with BT. My setting are 2272 downstream and 288 upstream. How do these figures appear to you?
Grateful for comments
Mike
ID
Doesnt look like you have been upgraded as your upload is still 288Kb/s when that chabged to 400+ you have been re-graded
