Slow Downloads
Slow Downloads
Try testing your line speed with ZDNET. I tested mine this evening and the best result I got was only
77.8 Kbps
9.5 K bytes/sec .
Just slightly better than a dial-up modem. What is going on Plusnet this isn't what we paid for?
espresso_mick
RE: Slow Downloads
This is what I got. Had a couple of tries.
Your line speed:
529.9 Kbps
64.9 K bytes/sec
Your line speed:
536.8 Kbps
65.8 K bytes/sec
chino
RE: Slow Downloads
Yeh fine here...
try turning off your firewall (just for a quick test) to see if that is slowing anthing down (it should not but it's possable)..
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
