Slow Connection
Slow Connection
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 18:36 to 18:37
Traceroute Duration: 1 minutes
Traceroute Packet Size: . bytes
Exchange: Scotstoun
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 395.7 kbps
Maximum Speed Achieved On PlusNet Speedtest: 434.8 kbps
Average Speed Achieved On PlusNet Speedtest: 415.25 kbps
Account: ADSL Office 1000 (20:1)
IP Block Size: 8
Ticket Number: None
Additional Information: None
flicker
Slow Connection
My connection is diabolical again tonight. Web pages are taking longer to load than when I was on dial up. Just done the speed test from ADSL site and got
Downstream 542 Kbps (67.8 KB/sec) 585 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps
and from the plusnet one : -
PlusNet Speed Test
Your current speed is:
706.10kbps
Slow Connection
Can you post a tracert to www.plus.net. I suspect you are effected by the high pings on pth-gw3 as in the first post which is slowing your connection down. Sometimes disconnecting and reconnecting a few times can get you off gw3 and get your speeds back.
PN are planning a router reboot tomorrow morning to hopefully solve this - see service status announcements for more details.
ID
Slow Connection
1st time i've had this happen since the problem started.
Fingers crossed for tomorrow.
1 2 ms <1 ms <1 ms xxxxxxxxxxxxxx [192.168.x.x]
2 15 ms 14 ms 15 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 619 ms 599 ms 614 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 605 ms 585 ms 570 ms gi4-0-23.pth-gw2.plus.net [195.166.129.219]
5 625 ms 627 ms 615 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 621 ms 624 ms 645 ms vl4.sec.ptb-gw3.plus.net [195.166.129.227]
7 601 ms 588 ms 588 ms if2.ptb-al1.plus.net [195.166.129.39]
8 605 ms 608 ms 598 ms www.plus.net [212.159.8.137]
flicker
Slow Connection
Thanks for the reply. I'm afraid I don't know how to do a trace route. I have tried disconnecting earlier but it didnt make any difference.
Slow Connection
flicker
Slow Connection
Thanks read that, know what to do, but don't know how you open DOS/Command prompt now! Shockedops:
Slow Connection
start -> run and enter either cmd (WinXP/2K/NT) or command (Win9x/Me) and click OK.
Or you could run the WinMTR app also detailed in that tutorial. Run it for a few minutes, click stop, click 'copy text to clipboard'. Then paste into a new post.
flicker
Slow Connection
Sussed it : Smiley
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 * * * Request timed out.
2 46 ms 52 ms 45 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 45 ms 52 ms * gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 54 ms 55 ms 54 ms gi5-0-22.pth-gw2.plus.net [195.166.129.213]
5 59 ms 60 ms 54 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 52 ms 47 ms 48 ms vl4.sec.ptb-gw3.plus.net [195.166.129.227]
7 58 ms 60 ms 61 ms if2.ptb-al1.plus.net [195.166.129.39]
8 54 ms 58 ms 48 ms portal.plus.net [212.159.8.137]
Trace complete.
Hope it means something to you,. :?
Slow Connection
If you compare your figures with those posted by mhall1976 for pth-gw3 entry, yours are not as high and thus your problem may not be caused by high pings as I originally thought.
Can you try an ADSLguide speed test now and see what you get? You may have disconnected and reconnected onto a faster connection without realising it.
Or just wait until tomorrow and see if the maintenance makes any difference to your speeds.
flicker
Slow Connection
Downstream 708 Kbps (88.5 KB/sec) 764 Kbps (inc. overheads)
Upstream 248 Kbps (31.0 KB/sec) 267 Kbps (inc. overheads)
Thanks, at least I learnt how to do something new. I will see what tomorrow brings then. It was fine yesterday, I had some of the best speeds ever.
flicker
Slow Connection
Still no improvement. Fed up.
682.70kbps
Sad
Slow Connection
If you are having speed problems please fill in the form at http://cgi.support.plus.com/faultreporting/ and paste the results in a contact us ticket and we can look into the problem for you.
flicker
Slow Connection
It's okay again tonight. It varies so much, and I have looked at all the information on the link you have kindly provided. However, whilst I have all the necessary things (anti-virus, up-to-date modem drivers etc) I haven't the technical ability to alter all my settings to do the BT test. I don't know how to do it. I got the technician from the shop I bought my wireless router to set it all up for me. However, if there was any problem with my equipment, surely it would always be slow? I have done the speed test three times in the last 10 minutes, and am getting:
939.50kbps
so I have no complaints at all tonight. I don't do a lot of downloading, but I always know when there is something wrong because this forum for instance takes forever to load, and other forums that I visi are even worse, one in particular can take upwards of 30 seconds to load the home paget. It is always in the evenings, and disconnecting and re-connecting rarely does any good at all. My exchange always shows a green/no problem so it's not this end. Thank you for your interest though.
