Slow - Adjust Settings?
jinje
I've just done a speed test as my connection is really slow. I've copied the message below. Now I know I'm in the middle of getting maxed so expected it but on the message it mentions I may be able to increase the speed of my connection by adjusting my settings - what settings (and where) should I be adjusting? Or do I just bear with it as I'm being maxed??
Thanks for any help recieved.
93.00kbps
Which means you can download at 11.63 KB/sec. from our servers. Our results show that your current speed is below the level we would expect for your product, you may be able to increase the speed of your connection by adjusting your settings.
1 REPLY
holdtight
Hi Gavin
This would be your MTU and RWIN settings and without going into too much detail here Kitz does a great tutorial on tweaking these settings and much more Here
You may also benefit from rebooting your router / modem once or twice for a couple of days then leaving it for the BT Bras to pick up as that is a very slow speed
Bill.
