Slooooooooooooooooooooooooooooooooooooooow
This is how bad it is
[root@Faith root]# traceroute news.bbc.co.uk
traceroute to newswww.bbc.net.uk (212.58.226.30), 30 hops max, 38 byte packets
1 10.0.0.138 (10.0.0.13Cool 1.636 ms 1.559 ms 0.958 ms
2 plusnet1-hg1.ilford.broadband.bt.net (217.41.128.200) 54.425 ms 24.678 ms 153.141 ms
3 217.41.128.130 (217.41.128.130) 41.144 ms 26.171 ms 217.41.128.129 (217.41.128.129) 25.175 ms
4 217.41.128.238 (217.41.128.23Cool 29.133 ms 217.41.128.234 (217.41.128.234) 26.810 ms 32.895 ms
5 dolpiaza.core.telehouse.plus.net (212.159.1.114) 365.022 ms 346.263 ms 299.737 ms
6 rt-linx-a.thdo.bbc.co.uk (195.66.224.103) 277.903 ms 302.866 ms 249.344 ms
7 *
[root@Faith root]# traceroute www.cnn.com
traceroute: Warning: www.cnn.com has multiple addresses; using 64.236.24.28
traceroute to cnn.com (64.236.24.2Cool, 30 hops max, 38 byte packets
1 10.0.0.138 (10.0.0.13Cool 1.681 ms 1.943 ms 1.213 ms
2 plusnet1-hg1.ilford.broadband.bt.net (217.41.128.200) 28.277 ms 25.354 ms 24.983 ms
3 217.41.128.130 (217.41.128.130) 28.514 ms 26.927 ms 217.41.128.129 (217.41.128.129) 27.672 ms
4 217.41.128.234 (217.41.128.234) 28.373 ms 217.41.128.238 (217.41.128.23Cool 28.424 ms 217.41.128.234 (217.41.128.234) 27.610 ms
5 * dolpiaza.core.telehouse.plus.net (212.159.1.114) 326.555 ms 315.303 ms
6 213.166.3.149 (213.166.3.149) 254.136 ms * *
7 213.232.64.50 (213.232.64.50) 241.644 ms 200.007 ms 240.646 ms
8 p6-2.london2-cr4.bbnplanet.net (212.133.14.89) 241.613 ms
And the ubiquitous ADSLGUIDE speedtest or as far as Plusnet is concerned the LACK of SPEED test
Starting speed test...
Do not use your connection until the test has finished.
>>> Speed: 175Kbps (down), 41Kbps (up) <<<
Test complete.
Ali
RE: Slooooooooooooooooooooooooooooooooooooooow
> 7 *
> Test complete.
> Ali
> Yeah I know the feeling I tested the speed and my downstream is a whopping 88kbitesps which is a little bit short of the 560 I signed up for- file downloads seem no faster than my old 56k modem
Refund time without BT excuses.
/me still on hold to support and it's been 40 mins
slow i know i am dling at 10k
I dont want to show how slow it is, the words downloading at 10k should say everything.
I got a technician and it is BT's fault gatway is goosed we know the problem but?.
Dont bother going onto complain you get the same reply.
RE: slow i know i am dling at 10k
He didnt actually say it was BT's fault but it was the same reply we got on the post to us all about slowness and packet loss.
I've had p**s poor speeds all night, so I decided to do a speed test at ADSL.org then post the results and guess what !
Direction Actual Speed True Speed
Downstream 434 Kbps (54.3 KB/sec) 499 Kbps (inc. overheads)
Upstream 171 Kbps (21.4 KB/sec) 196 Kbps (inc. overheads)
This was at 11:00pm. These slow and fast speeds seem to coincide with people coming home from work and going to bed. It all seems to point to an overloaded system. What do you think ? I must say though, the last week has been OK until tonight.
Regards, John Taylor
plusnetsux
downloads are fine here, 60k/sec constant any time of the day (cardiff exchange)
uploads a bit slow though only 10k a second ! - should be 30 ish.
> > 7 *
> > Test complete.
> > Ali
I am on a different unmetered ISP while I wait for my ADSL problem to be sorted out and I did the speed test twice and these are the results:
>>> Speed: 22Kbps (down), 63Kbps (up) <<<
Test complete.
>>> Speed: 24Kbps (down), 64Kbps (up) <<<
Test complete.
As you can see the upstream speed is kinda dodgey to say the least since I am only on a 56k modem. So maybe there is some error in these speed tests.
Asim.
Just a reminder guys and gals...
ADSL is a contended serive. You are NOT guranteed a 512k download or 256k (bit) upload. It can be contended at ratios as much as 50:1 for home users or 20:1 for business users.
Work it out in bytes/s and [pardon the rounding] your lowest downstram speed could be 1.25k/bytes per second and upstream could be as 'bad' as .625k/bytes per second.
This is a fact of life as far as ADSL is concerned - if you want guaranteed bandwidth, get [lease] a leased line!
And no I'm not a PlusNet employee - just reminding you all of the limitations of ADSL Smiley
Contention hasn't kicked in yet.
And no I'm not a plusnet employee either.
I was getting poor connection on 13/08/02 aswell.
it's been ongoing now for ages, some nights are good, most thou are really bad!.
For example i downloaded a 29mb program the other day "DVD Movie Factory" which would have download at 50K max for me before, but guess what it was only 8K download!!. It's a joke now.
Also i want to add, people complain about the Downstream, but what about the Upstream? i consider this very important too, and for the past month i've only been getting 6K/bs to 19 or 20 K/bs intermitently .. it goes up and down again like a YoYo.
My FTP transfers are as fast as a dialup 56K modem now. rubbish!.
Just wanted to add my latest here, although i expect it will make no difference, as i have been posting reports here most of the month and last.
Put it this way.. when i joined PlusNet ADSL i couldn't believe my eyes.. i was so used to a dialup modem all my 6 years online, and to see everything move so fast was just too good, exactly.. just to good to be true. From April to June it was great, July it started to slow down, and August is a joke!.. now it's no better than what i have said above!
Jason
Hello all,
How's it performing today? There was a generic fault on the ADSL network last night which effected the level of bandwidth available to us.
This returned to normal as of about 0100hrs today.
Please accept our apologies for this drop in performance yesterday evening. We're investigating the exact cause together with BT.
Regards, Torsten.
| Torsten Dettlaff...............Unmetered & ADSL solutions
| Customer Support......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
Hello Torsten,
Things seem Ok at moment,
it normally gets bad between 6pm to midnight when people get home from work.
I'll update this thread later with peak user-time results.
Jason
elton
> Hello Torsten,
> Jason
Maybe it gets bad betwen 6pm to midnight when people get home from work and start doing speed test after speed test after speed test, in a never ending quest to prove they're 'only' getting 310/127 Kb/s. Thereby flooding the internet (and PlusNet's pipes in particular) with pointless traffic, which slows everyone else's connection down.
It's just a thought.
Skonko!
download the new drivers for ur modem. shud sort it.
