Sky TV phone socket
quizereus
Sky TV phone socket
since installing ADSL last year, I can no longer order films Via my Sky remote control.
I have to phone Sky direct.
It does not matter whether there is a splitter on the line or not.
Is this a common problem?
Any advice will be gratefully recieved
RE: Sky TV phone socket
Hi there
I spoke to friend from office who has broadband - I mentioned your problem, I have Sky also ! - he said you have not configured your lines correctly - i.e. after splitting your lines, your sky must be linked to phone side.
This assumes you have not linked your sky line before splitting the lines - do you follow !
Hope this helps.
Any telecoms device, must be filtered on a DSL line, with the exception of the DSL modem itself
u MUST connect the sky through your filter otherwise u will be disconnected EVeRY time UR Digibox tries to dial out, (NE way i think the problem is with ur DIGIBOX)
............./??/'...'/Huh`??
..........''............. _.??
NE & 3VRY 1 :naughty:
As far as I can remember the SKY engineer wired the digibox telephone cable straight into the wall connector box.
Do you need a kit to convert the connection so it can go through a micr filter and splitter if a telephno handset is connected to the same line?
