Size of monthly Internet Usage
I am on a contract for 512Mb connection, but I would change to a 1Mb connection at a cheaper rate if I knew that I was using less than 2Gig per month. Is there any way of finding out what my actual usage is?
Just go to the "View My usage" option.
Connection settings on the left of this page and then select "view my usage" from the box trhat appears.
Monthly Usage
Many thanks for your advice John. I now have the information that I want. Usage is far less than I anticipated.
Usage reads zero
Hi
I have checked my usage and it says 0GB today and 0GB all week.and 0GB in a month
Just today I have been logged on for 5 hours have uploaded several meg to my personal web site and downloaded a few files and this is not unusual Why is this?
Pete :?
Uploading and Downloading to or from your site does not add to the usage count.
However you should see some usage if you have been surfing ther net or downloading files from elseware.
If it shows nothing at all then I think its time to raise a link:Contact us ticket and get it looked at.
