Sites unavailable
Sites unavailable
My broadband was activated on Friday after migrating to plus.net. I can connect fine, but certain sites are un available. Blogger.com, Digg.com and a few others. They just time out and I get a "Site unavailable" error.
I could see them fine with wanadoo BB. I have gone through a proxy server and can see them so I know they are not down.
Can anyone tell me what is causing this?
Kind regards,
Simon Ward
Sites unavailable
Can you tell us which DNS servers you are connected to, if your using a usb modem then you can find this out by going to start and run and typing cmd then type nslookup blogger.com and paste the results you get.
Cheers
Sites unavailable
Thanks for the quick reply. I'm using a Mac, so I'm not sure if the results will be different.
NSLOOKUP retirns:
Server:         10.0.1.1
Address: 10.0.1.1#53
Non-authoritative answer:
Address: 66.102.15.100
DIG returns:
 <<>> DiG 9.2.2 <<>> blogger.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 63840
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;blogger.com. IN A
;; ANSWER SECTION:
blogger.com. 1508 IN A 66.102.15.100
;; Query time: 3 msec
;; SERVER: 10.0.1.1#53(10.0.1.1)
;; WHEN: Sun Jul 2 21:35:47 2006
;; MSG SIZE rcvd: 45
Thanks for your help.
S
Sites unavailable
can you try accessing the site using http://66.102.15.100 and see if that works
Sites unavailable
Check your DNS server setting;
http://portal.plus.net/support/member_features/at_a_glance.shtml
DNS – primary 212.159.13.49
DNS – secondary 212.159.13.50
Chilly
Sites unavailable
Go to System preferences panel and select network panel.
Click on TCP/IP tab and enter under DNS Servers.
212.159.13.49
212.159.13.50
212.159.6.9
212.159.6.10
Dave
Sites unavailable
Thanks for all your help. As soon as I get back tonight I'll try these and let you know how they go.
Thanks again
Simon
Sites unavailable
Just an update on this.
I tried all of the above but to no avail. When the plus.net BB was activated, I had simply changed my username and password.
So I re-ran the setup wizard and created a new connection from scratch and it now works fine.
It appears the router was still using settings which it had automatically detected (DNS servers etc) from when I installed Wanadoo BB.
S
Sites unavailable
Glad you're sorted.
Dave
