Simultaneous Broadband and Dial-up
steadyeddie
I have a wireless router with several PC's and laptops connected to the ADSL side of the filter and onwards to PlusNet, and a telephone to the other.
Is it possible to remove the phone from the filter and attach a laptop with dial-up modem to dial to an ISP other than PlusNet.
I am getting "no dial tone" from the modem, so not sure if it is an ADSL issue, or a Modem/Cable issue to the phone side.
Regards.....
ps. Just noticed, a bit similar to the post below !!!!!!!!!!!
Yes nothing to stop you using a dial up connection to a different provider at the same time as your ADSL one.
steadyeddie
Thanks John,
I will check out the modem / cable end of things.
Regards ...................
Its possible but the dialup would connect at a really slow speed.
hitachi
Er why?
My dialup is the same 48k as it was before adsl.
It did slow mine down a little bit, but it only went from its original 42K to 40K.
