Simple question's- Simple answer's
Would somebody please be so kind as to simply tell me the acceptable amounts of data i can download/upload per month on both the 1,2 mb premier.
It may be a simple question but there is no simple answer...
There is no official figure but if you stay under 100GB/month you should be fine. However this is not a cap and you can go over it.
The reason there is no simple answer is because plusnet have not officially stated anything (the 100GB has just been mentioned as something being considered).
thanks very much
in my view its a rule of thumb really, you can use over 100GB in 1 month just as long as you dont make a habit of it i suppose :?:
so does that include the 2 mb premier aswell?
It applies to all speeds.
