Simple Question
cranwin
Simple Question
PN now report my MSR to be 7500.... Yippee!
My router Sync. is 8096..... Yippee!
What sort of actual download speeds should I expect?
Simple Question
1k yipeee!
The best answer is to do a speed test on the portal as this gives you the download rate after it has tested your speed
cranwin
Simple Question
yeah! have done all of the speedtests and it varies wildly dependant on time of day etc. But the simple question is with a good stable connection and a line rate of 7500Kbps what actual download spedds should I be able to get....?
100Kbps?
500Kbps?
1000Kbps?
what would a reasonable speed be for this type of connection?
