Signal dropout
Signal dropout
Hey all
For a while now I have been getting some sort of signal loss/dropout where my router appears to loose contact with the ISP (my ADSL light flashes telling me it is trying to get a signal). I've run the PN fault checker a couple of times, including once just after I lost my signal, and it says nothing is wrong... because when I run the checker I have obviously been reconnected. It doesnt seem to be time of usage dependent, and it can often take ages to reconnect, though my brother found by turning the router off and on again, you can get it to reconnect.
Does this sound like a problem with the router or could it be a line fault?
Regards
TheMaster
