Should i update my voyager 105
Fantasticfourum
I notice that the Voyager105 has been superceeded by several models would there be any benefit in upgrading and if so which is the best to upgrade to. I am not having any trouble with the Voyager so maybe i shouldnt fix it if it aint broke as they say.
Plusnet Staff
Plusnet Staff
Depends really on what you want to do. If you have more than one PC or want to connect wirelessly then I'd say upgrade to a router, if you're planning on getting Vista then again I'd say upgrade because the 105 doesn't have drivers for Vista.
Fantasticfourum
Ok thanks for your reply
