Should Software Compression be enabled with ADSL
As above really, I know that with 56k it use to help, but should it be enabled with PlusNet ADSL.
Do PlusNet support compression over ADSL?
RE: Should Software Compression be enabled with ADSL
Forgot to mention, above is under windows XP.
rz2k7
I'm running windows XP with a Efficient 3060 pci adsl modem. I have found turning "compression" off, turning "LCP extensions" off and turning "negotiate multi-link for single link extensions" off gives me a much quicker connection to +net. Also my browsing seems to be quicker too.
You can only try and see if it works for you.
