Sharing Binatone (3 light) modem connection
Help,
Can anyone help me to share the connection of my binatone adsl 500 modem. I've tried looking through the forum and had no luck finding info, so if one of youo kind people could point me in the ringht direction it would be appreciated
FHDawson
If you mean 2 or more PCs connected to net at the same time, using the USB modem, then look in your Windows help for Internet Connection Sharing wizard
I've seen several threads in the computing & hardware forum
You will need the main PC running to share the connection.
Sorry, can't tell you exactly how to do it, I've never tried, I use a cheap Router.
Jeff
Thanks cank, i've tried that, probably shuould have said in my first post. I'm running a fresh installation of win me and there is no icon in the dialup section to share. It was all runnning fine until upgrading my system and having to do a reinstal.
FHDawson
