Shared PC browsing problem
My ADSL connection has just gone live and I can browse with no problem, but other users on this PC (using their own logins) cannot.
They get an error in IE saying:
Forbidden
You were denied access because:
Access denied by access control list.
Yet they can browse if they connect via a dial-up.
I'm using Win XP and the PlusNet-supplied router.
Any ideas, anyone?
Cheers
Forget it - I found the problem. There was a proxy set in IE for the other users.
By any chance have you switched from a Freeserve Dialup?
If not, I sugest running software like AdAware and SpyBot Search and Destroy. This is a good idea anyhow.
A proxy server being listed can point to setings left behind by a previous ISP. In other curcumstances. it is caused byt SpyWare proxying your data, and at the same time, logging activity.
