Shairng Broadband Connection
I am purchasing a new PC and looking to share my Broadband connection with my current PC, could anybody recommend the best equipment to do this. Or alternativly, please provide a link to a suatable site that will provide the info. At present I have a USB modem as supplied by PN, I guess I need to be looking at a combined ASDL modem / roulter plus network cards or wireless.
Many Thanks
David
Moderators note by John (johnessex) Topic moved to a more apt location
I use Draytek Vigor 2600's and find them quite stable, although pricey, they offer VPN connectivity and a lot more than many other routers on the market.
Roy
Fixes: 57
I found this site very useful
http://www.broadbandbuyer.co.uk/
You can find loads of reviews on routers at http://www.adslguide.org/reviews.
chroma
Broadband Modem/Router recommendation
I've just installed a Netgear DG834G to share my Broadband connection with both my wired network computers and to provide a roaming wireless link to a laptop. Was very easy to setup and is working well. Definately recommended.
Even if you only intend using one wired computer at present, it does give you future options for expansion.
