Settings in xp.
nitrodeluxe
Settings in xp.
I have just upgraded to xp home,and when i load my modem drivers,set up the config for my settings,it connects ok,but when i restart my comp,i have to uninstall the drivers ,reinstall,for the modem to connect.It seems the settings are not saving?.Everything worked ok in win 98.It maybe obvious,but as i say iv just changed os.
RE: Settings in xp.
What modem are you using ??
Have you got the lastest drivers for XP?
nitrodeluxe
RE: Settings in xp.
> modem is a connexant pci, xp drivers upto date
RE: Settings in xp.
Did you make sure that you un-installed all drivers etc. before upgrading ??
nitrodeluxe
RE: Settings in xp.
Sorted problem,it seems connexant has its problems
win xp being one of them. new modem drivers did the trick.
thanks anyway.
RE: Settings in xp.
> thanks anyway.
Is it a usb(A360)or pci A220 modem?
If the A360 USB then there should be no probs with XP.
LastRoMan
Settings in xp.
Hi gupp34,
I have the same problem - though it is intermittent as - I went for over 6 months with no probs - then one day it flared up again. I have XP on a 450Mhz PC using a Dabbs Connexant PCI internal modem.
I also find I only need to uninstall the one driver - ADSL PCI Interface - then when I boot up - with the CD in place it only takes an extra 5 minutes instead of 15!
Which Drivers did you find worked best for XP please?
Thanks, Conrad :?
nitrodeluxe
Settings in xp.
Got drivers from here themad-house.co.uk , latest drivers
LastRoMan
Settings in xp.
Thanks I'll d/load the latest and see if I can remedy it.
Cheers
