Settings for ADSL modems
robstreats
There is an article on the ADSLGUIDE web page that says that BT recommend maximum packet length to be set at 1458 for both receive & transmit. I've tried it and it seems to be slightly quicker.
Robin M Streatfield
RE: Settings for ADSL modems
where did u put the 1458 value? are you using the accessrunner software?
robstreats
Yes I am using the Access Rnner s/w. Go to Access Runner Controp Panel - hit Alt + C, then the protocol set up Tab & enter 1458 in receive & Transmit.
Let us know how you get on.
Jim
try this link
http://www.dslreports.com/faq/tweaks
you can download DrTCP to adjust MTU and RWIN settings
