Setting up wireless Voyager 2110 on 3 yr old Dell Dimension.
Hoping to switch to plusnet any day now and have purchased the Bt Router 2110. I aim to switch to wireless on my Desktop Dell Dimension 2400 Series. Will this support wireles or will I have to install a wireless adapter through a USB port before I can begin to switch to router. The set-up guide says I must set up wirelessly first and only then can I connect the fixed ethernet line. If I don't have a wireless facility inbuilt in my desktop then I can'd figure out how this can work.
Anyone advise? :?:
dmcd11
1 REPLY
Plusnet Leader
Plusnet Leader
Normally you would set the connection up ethernet first and then configure the wireless connection.
You will need a USB wireless adaptor but it should be pretty simple to set up wirelessly after you have the ethernet connection established.
