Setting up an FTP server
How do I configure an ftp server on the following setup:
2 pcs on a Netgear DG814 router, I have a static ip for the router and it is set as a DHCP host for my 2 pcs.
I have my ftp server software setup on 1 pc, how do I make it visible to the people who need to see it?
I'm very new to this router/firewall malarky.
1 REPLY
You need to use port forwarding. On the machine which has the FTP server running on it press
Start  > Run > type "Command" > type "ipconfig" in the black box which appears
This tells you the internal IP.
Then in the router setup [usually accessible through 192.168.0.1 or similar] setup port forwarding for port 21 to whatever IP you found out above.
Setting up port forwarding
Once you're in your router's setup [192.168.0.1] follow these steps to add the FTP port to be forwarded :
1/ From the main menu of the router configuration, click "Advanced" and then "Port forwarding".
You should see a screen like this [may not be exactly the same, depending on firmware version].
2/ I will assume your FTP is running on the default port [21] so just
-Change the drop down menu under "Service & Game" to "FTP".
-Where it says "Server IP Address" enter the IP of the PC running the FTP server [which we found out above /\].
-Finally, press "Add Server".
This should add the port, and your FTP will now be accessible by people outside of your network.
*NOTE* : Inside of your network, you will not be able to access the ftp using the same address as people outside the network would. You must use the internal IP [the same one we found through ipconfig]. I'm not sure why, but it's something to do with NAT.
For example...: I use 192.168.0.5:21 to access my FTP server, but people outside of my network use 212.159.20.40:21.
You can test that your FTP is working by going to www.web2ftp.com and entering your server details - this is basically a person outside of your network connecting, so it tests the port forwarding.
Any further queries, don't hesitate Smiley
