Setting up a VPN
willow147
Setting up a VPN
Hi all,
Excuse my ignorance here but I know nothing about networking.
I have a PC, USB ADSL Modem and a +net connection, my friend has a PC, USB ADSL modem and a Zen connection.
Is it possible for us to set up a VPN and if so, HowHuh
thanks in advance
Setting up a VPN
You don't say the OS that you are using on either end, but if you are using a relatively recent OS (2k, XP) it should be relatively easy.
Let us know which OS you're both using, and I'm sure someone can help you!
B.
willow147
Setting up a VPN
We are both using Windows XP Pro.
