Setting up VPN for home
barryg
I would like to set up my PC so I can access it from the office using VPN. I have the USR ADSL router and just wanted to know if this was possible. If so does anyone know how? Would I use the fixed IP address that plusnet provide?
Hope you can help
Regards
Adrian
RE: Setting up VPN for home
There are no restrictions on your connection itself that would prevent VPN usage - you may be advised to check with USR that their router supports this type of traffic forwarding however.
Regards,
Richard
| Richard Allen................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
bluewhale
It might be nice if plusnet could make it clear on you adsl help pages that some routers don't support VPN.
That way people like my self won't buy equipment that won't work...
In particular you need to look for the router either supporting VPN or IPsec passthrough or possibly port mapping using protocols other than UDP and TCP
kitz
GOOD POINT ^^
Having just signed up for a router starter pack with plusnet
Does the router supplied by Plusnet support VPN?
kitz
Ooops just spotted the following in an older thread
The PCI and USB modems both work as a direct replacement for a standard modem, ie your machine is assigned real IP addresses and all services will work without further intervention.
The Solwise SAR110 router we supply supports IPSEC forwarding, so VPN protocols that use this will work fine.
However, as mentioned by the previous poster, it perhaps would be a good idea to mention this information on the main site, and also which make & model of router you provide.
Thanks Smiley
