Sending PN emails via OE6
I've used outlook express for ages with my emails with BT since add my PN accounts i've had problems. I can receive emails from PN but i cannot send form PN via OE6. I can't see what the problem is! Anyone got any suggestions. Cheers
This is teh message i get!
This is the message i get...
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'jfitzgerald1979@aol.com'. Subject 'test', Account: 'mail.plus.net', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
Th aol account is fine, it shows this message whomever i send to.
This is because you are trying to relay a message over the BT mail server when connected to a Plusnet account. If you go into Outlook Express and click:
Tools
Accounts
Mail
Select the accounts causing the problem
Properties
Servers
Change the SMTP server to relay.plus.net
Do NOT tick the Outgoing Mail Server Requires Authentication box
Click Apply
Click OK
Problem fixed Smiley
Thanks but please i am already doing that. I've since checked the error message in the PN help bit. I've tested port 25 via telnet. That works. I've also tried relay1.plus.net but still no joy!!! Ahhh
Tried deleting and recreating the account?Huh
swatty
This is an issue with SMTP server
A 550 relay error is generally an issue with the configuration of the SMTP server. Given that you are getting an 0x800CCC79 Error in OE6 would suggest that the SMTP server is not regonising you as a +Net account holder, and thinks you are trying to SPAM it.
Speak to +Net before you do anything.
Can you confirm that the Outgoing Mail Server Requires Authentication box is definately not ticked?
Definately is not ticked.
I have set up three email address already see see if it was just a single email address problem but the problem above occurs for all of them.
Could it be because the migration hasn't completed? I can't see how, as thats just a line thing and PN said i can start using everything.
Ah right.
If you are still connected with your old isp then you must use their smtp servers. The Plus Net servers will reject you until your migration completes.
If your still with BT, use their smtp settings for now.
Hope that clears that one up for you.
WooHoo!
Woohoo! Thankyou v much. That totally works, using the Bt server, username and password to send PN emails. Can't believe it works but it does. Cheers PN
