Seems slowwwwww
Seems slowwwwww
It's very odd this morning but trying to access some sites seem to be slowwwwwww this morning, but the speed test says it full stream ahead, anybody else getting any speed problems.
RE: Seems slowwwwww
It's going to be the other end then isn't it?
After all, Plusnet don't control the rest of the internet. There may have been some problems with the 'big' pipes between here and there, so it had to go the long way round....
BR
Jim
RE: Seems slowwwwww
yes I experienced the same problem around about 10:00am. Everything seems OK know.
