Security
Security
With the adsl plus do we pay extra for the security features? Under services it lists firewall, antivirus and spam but not sure if this is extra. Thanks
craigbrass
Security
You get free E-mail Virus Scanning and E-Mail Spam Protection according to the product specification on http://www.plus.net/residential/broadband/broadband_plus.shtml under security. You just go to "Email Settings" in the portal under "My Acount" and the icons are there for you click on and configure the services.
A computer firewall you would have to either purchase the security package from PlusNet or get one seporatly. I recomend getting it seporatly and I recomend McAfee's Security Suite. £50 one off fee from http://www.mcafee.co.uk and then £20 a year subscription renewals.
Security
Hi Thanks for the info. I saw the specification but wasn't sure as found something else which said about it costing extra.
Security
andyfan, also bare in mind most ADSL routers come with built in firewalls...
Security
And although simple, bloomin' good un's too! :twisted:
Security
I think the Voyager 205 comes with firewall enabled but I have no idea how I would check this as couldn't find anything in the instructions. I'm using Zonealarm as well to stop puter blabing. Thing that concerns me though are all the inward logs tcp blocked which say it is Voyager.home anyone know if that it is right blocking them?!
I've enabled the plusnet spam and antivirus (although have a very good one on pc anyway).
