Screen size
villario84
Screen size
Why do I only see the left half of a screen on all web pages
Screen size
I don't know... why do you only see the left half of a screen on all web pages?
<waits for punchline>... OH, OK...
How long has this being going on?
Is it ALL websites or just some?
Tried rebooting PC & router?
Screen size
What resolution have you got your screen set to?
If you have it low ie 800*600 or lower then a lot of pages are set to a bigger size try uping you screen res
bikepump
Screen size
if your screen is widescreen aspect ratio that'll be why - ie if it's rectangular not square Wink
James
Screen size
If you right click on an empty area of your desktop and then go to the "settings" tab, you can then change your screen resolution from there.
