Samsung AHT-E300 ADSL Router setup? ( like the Conexant Rout
I need help with get my adsl working...
I am a total noob to this ( used to have cable)
I have a domain server.. that the router is plugged into an ethernet card
the modem syncs up fine.
i go into the web based management http://10.0.0.2
and then...... I start to get lost..
the adsl section is showing that it's connected
the LAN says there is 1 ethernet devices connected (my server)
Ive enabled the dchp server
i've changed the dns to
212.159.11.150
212.159.13.150
VPI = 0
VCI = 38
static ip = 0.0.0.0.0 ( WHERE DO I FIND OUT IF I HAVE A STATIC IP OR NOT?)
NAT ( WHAT SOULD I SET THAT AS?)
VIRTUAL SERVER ( Huh??)
BRIDGE FILTERING (Huh??)
IGMP (Huh?)
MISC CONFIGURATIONS
WAN side HTTP (Huh??)
DMZ (Huh??)
DMZ HOST IP (Huh??)
PPP reconnect on WAN access (Huh?)
I did the diagnostic tests and they all passed
but i still can't access the web...
ping an outside source..
ftp... etc etc
(unfortunatley the instructions that came with the modem wasn't much help)
then i start to get really lost..
has anyone set this modem up b4 if so is there just a bog starndard settings that work. so then i can play around with at a later date...
RE: Samsung AHT-E300 ADSL Router setup? ( like the Conexant
I've managed to get this router going!!!
I bought it on the thursday, tryed to get it to connect to the net for 6 hours before giving up!
Then yesterday, i saw your post and changed a few settings and it passed the second from last diagnostic which it was stuck on previously.
Then i told dhcp to change all my ip's in the range of 10.0.0.3 to 10.0.0.254.
Put in the gateway in the dns settings - not plus.net - but the actual gateway ip, you can find this out in the routing table section..
Your static ip if you have chosen the £22.99 option, is also in here.
Once i did that i renewed my network settings so it got the new values from dhcp, and double clicked on Internet explorer!! Success.
I did also put manual settings in the DNS entry on the TCP/IP settings on my network adapter, i think that helped!
thanx for replying... ( I've eventually got the thing working... err wel-ish... it all up and running but i still need to configure it a bit better..
i can get the internet on all pc fine. but ip routing isn't sorted properly
I'll explain my setup..
samsung adsl modem/router public ip 212.***.***.***
internal ip 10.0.0.2
I've enabled dhcp.. on it
this then goes into a network card in my server. ( network card ip 10.0.0.7)
on the server i have enabled routing (don't want to use ICS )
the network card leaving the server (ip 169.254......)
goes into a hub. which feeds to 2 clients.
(both with ips of 169.254 ... ...
Ideally what i wanted to do is to have the router dealing out the ip address 10.0.0.3-10.0.0.14
It gave my servers 1st network card the correct ip.
but didn't pass it on to the rest of the networkHuh
what am i doing wrong??
another problem i have with it is when i enter my public ip.. from another location... e.g to view my webpage... ( via IIS) I get the router config) in other words the router isn't passing the request onto the server...
Sounds like you need to set up a DNS server on your server, i've got mine connected to a hub, both my pcs get their info from the dhcp on the router, and my server too.
You need to add a service in the networking part of control panel on nt4 and 2000.
then tell your machines that your server is the primary dns server, so that all the requests go through this..
Not totally sure how to set this up properly, so you may need to go to a website or two....
