Safecom SWAMR-54108
mooneyfamily
Safecom SWAMR-54108
I have just bought this from ebuyer and I wanted to check that I had correctly set it up.
I cannot find the details for setting up a router on Plusnet.
My Account > Connection settings doesn't help.
Can anyone point me in the right direction please.
Thanks,
Peter
Safecom SWAMR-54108
Hi peter,
if you want to post the questions the router is posing we should be able to help.
for starters
username = yourusername@plusdsl.net
Password = as per sign up
VPI = 0
VCI =38
Encaps = PPPOA (PPP over ATM)
Your Ip address should be automatically assigned.
Safecom SWAMR-54108
BTW
For further info see this and also Safecoms forums here
mooneyfamily
Safecom SWAMR-54108
Thanks Mark,
I think that I have got all that.
I have been to Safecom's website and the forum.
I was just after any Plusnet specific settings. As there are a lot more options than are given in my connections on Plusnet
For the modem mode there are for options:
MMODE
T1413
GDMT
GLITE
MMODE has been automatically selected is that correct?
Peter
signature now added Smiley
holdtight
Safecom SWAMR-54108
Hi Peter its been a while since i used a modem but if i remember rightly MMODE is multimode setting which is fine for you
GDMT would also be ok but dont use the others
Safecom SWAMR-54108
Hi again Peter,
yes Holdtight is correct Multi mode will work as will GDMT
Hope you get sorted.
