SQL block
SQL block
Can anybody tell me for how long the MSSQL will be block for.
1 REPLY
fonejacker
RE: SQL block
HI There,
There is no easy answer to that. The honest answer is that "Until the vast majority of users (On the Internet) have patched to prevent the worm being distributed then the keepalive SQL ports will remain blocked"
With Regards,
Ian Wild
PlusNet Customer Support
