SNR on line
kreynolds
SNR on line
Just a quick question
These are the SNR Redings on my line, was wondering as to whether the SNR was just within the limit for 1Mb as I can't remember what it is.
TIA
DSL Parameters and Status
Vendor ID: 00B5GSPN
Revision Number: Y1.16.3
Serial Number: Solwise-271003d
Local Tx Power: 11.75 dB
Remote Tx Power: 17.66 dB
Local Line Atten.: 26.0 dB
Remote Line Atten.: 18.0 dB
Local SNR Margin: 40.0 dB
Remote SNR Margin: 26.0 dB
Self Test: Passed
DSL Standard: G.dmt
Trellis Coding: Enable
Framing Structure: Framing-3
Config Data Up Down
Intrlvd Fast Intrlvd Fast
AS0(kbps): - - 0 1152
AS1(kbps): - - 0 0
LS0(kbps): 0 288 - -
LS1(kbps): 0 0 - -
RValue: 0 0 0 0
SValue: 1 1
DValue: 1 1
SNR on line
These are pretty good values and are well within the limits for 1 & 2Mb services.
The higher the SNR and the lower the attuation the better
kreynolds
SNR on line
Thanks 4 that.
It would explain my speeds....usually 970 +
