SMTP Mail questions
SMTP Mail questions
How long should it take to dequeue mail via a finger command?
Is it possible to check how much mail is stored, waiting to be de-queued?
Thanks!
1 REPLY
kissack
SMTP Mail questions
should be immediate after a finger although if there is a lot of mail it may take a while. I noted that some mail seemed to be held elsewhere on failure of smtp server (ie didnt immediatley pass to autoturn) and this mail had to wait for the sending MTA to retry and thus send on.
I did have a problem where finger didnt work! Are you getting a repsonse to finger?
Allan
akissack at gmail dot com
